Pro1200se
California
So here's where I'am at now. HUGO TRIED everything and even called some of his mechanic friends.
When it cold it runs great, when it hot it goes into limp mode.
And the injector code lights up.
He took off the airflow sensor and it ran great.
He believes its could possibly the catylic converter.
But he said hes not charging me anything.
And to take it to the dealership.
He left the clutch drive in place but removed the seats and Doghouse.
I took it back to the local dealership and showed them.
They brought out the service manager and he said it looks like there's plenty of room to operate and that they'll work on it.
Here's hoping they can find the problem and get it going.
I wish I was more mechanical and able to heat shield all the wires.
I'll have this thing for 3 years in march and 42000 miles on it. Was hoping to get a solid 5 and sell it.
But I feel bad selling it to anybody now
California
My ultimate thought is Sapphire doesn't charge as much as say Butler, CDS and CLeanco are comparable price wise but they include some features to protect the van.
I know Sapphire has fixes for the summit.
They need to help existing owners get thier units running and protected.
Sell a upgrade kit at cost, and allow the distributors mechanic to install fixes that the owner of the pro1200 pays the mechanic to do.
It's worth getting the upgrades at a good deal.
The good deal gives us hope and helps to reduce our down time which in some cases is bordering on rediculous.
Wire heats shielding fan upgrade whatever it takes to make end users happy again.
but they need to help existing owners get thier units running a protected.
sell a upgrade kit at cost, and allow the distributors mechanic to install fixes that the owner of the pro1200 pays.
it worth getting the upgrades at a good deal.
the good deal gives us hope and helps to reduce our down time which in some cases is bordering on rediculous.
You can get high temperature spark plug wires. About $150 for a set.
Did you call Laura?
Trying to make heads or tales of your tourettish rants is as much of a clusterfuvk as your wiring issues
  • Dislike
Chris A
OH
call Laura.
Bitching on Yelp will get you nowhere.
Did you see the Facebook thread where literally everyone who's every bought a pro1200se, and is active on FB has chimed in with the same issues? It's not like Sam is alone in this? I'm taking mine in so I don't really have a dog in the didn't anymore but their "fix" is anything but...
Chris A
OH
Not to mention our mutual friends in Florida and Arizona who haven't spoke up but sold their 1200s awful quick after buying them...
Reactions: hogjowl
FB7777
Perhaps the my tee Legend Brands can buy a Brand new Butler and reverse engineer what components are different and possibly causing the issue
totally sucks Sam, and you’re a good guy for not wanting to dump this problem onto someone else
REALLY sucks that you are relatively mechanically inclined to run slide ins all these years, only to switch to a direct drive for simplicity and get this lemon
FB7777
Damned if I know, but I remember Sam mentioning how the PRO1200 directs the blower exhaust straight down under the truck.... I imagine that the temp under the van is constantly much hotter and humid than a PTO that diverts it away from the undercarriage
Chris A
OH
I think that has something to do with it, I also think running the van at 1000-1300 rpms, compared to the others 1700 or so may affect cooling
Chris A
OH
I also can't speak for Sam, but my 2 rigs have been maintained to the letter of the manual. My dealers only a half hour away so I have them do everything and have all records
I saw it but didn't study the comments.
When you say the fix, do you mean the recent set of re-engeneered replacement parts that were being offered?
Those were announced back in September I believe, no good?
Chris A
OH
The fix is a flex fan direct bolted to the water pump. I'm not sure what testing they did but it broke the pulley off of my brand new water pump within a month. I did the spark plug and wire fix about a year-and-a-half ago on both vans and both are showing signs of needing plugs and wires again which is about $1,000 because of how much of a pain in the ass it is to get to them.
California
As bad as Hugo the mechanic was at finding my problem.
He pulled the seats and slid the dog house out unscrewed plastic piece.
And there's a lot more room to operate.
I'm sure doing it this way is cheaper then having a distributor pull the direct drive and replace it.
$650 and that's with out having work done on the van.
If you want the doghouse out on these Van's the seat has to come out anyway
California
The real issue isn't that they made fixes!
Its can they be trusted to help end users if say there's other issues????
Right now I would say no.
Mark Saiger
Mr Happy!
Grand Rapids, MN
Mark Saiger
as impartial shEEtrockhED that doesn't do faqbook to hear the scuttlebutt ….
but know Sam and Chris aren't clueless dolts...
what's the big difference under the hood and covers in Butlers, HMs and Cleancolds that they don't seem to suffer so greatly?
Well I know but not sure I should share everything...
Oh what the heck....
*All stainless
*Front fan clutch switched to a non thermal clutch
*Larger fan installed and it gets pulled back a bit so the radiator shroud has a small modification
*Those couple of items help to cool the entire unit all the way to the back of the van
* units placement in the van balanced for the van.. *So one ton units will get an upgraded coil spring in front
*smaller alternator required so the drive shaft fits nice and easy under the hood with an amazing clutch and NO GREASE shaft!
*thermostat taken out of the motor and an external thermostat installed with the perfect amount of space for the thermostat now to get ultimate heat from the Butler and the Butler and van together run at a perfect temp.... All the time!
*with above it's important to run with the van hood closed
*Their heat exchanger set up also helps with the flow of the van so captures max heat from van and the second heat exchanger off the Blower. *Great suction due to large plumbing for vaccum yet it also helps the entire unit.
*Dual belts so you don't have to worry about perfect single belt alignment
*These are a few items that come to mind
*we have put on thousands of miles and thousands of hours on our Butlers and vans
I have no experience with Butler, except for trying out Marks a couple of times. Here we mainly have Hydramasters and Cleancos. Not sure what modifications they make to the vehicles but you will see many cleaning units that have far outlasted the van they were installed in. Not uncommon for someone to buy a 20 year old unit with thousands of hours on it for a back up machine or starter machine. Part of the problem seems to be the GM van. I remember Bryan (Great Oz) saying something about problems with new Hydramasters.
Reactions: Chris A
I was very very close to buying a new Butler, my experience with these two trucks has turned me away from direct drive all together but I truly believe Butler's are top-notch machines and an even better company
Were you or the other disgruntled 1200 owners popping the hood on every job?
I know Butler says not to but sounds like a probable fix for the 1200 baking issues
Chris A
OH
I never have, on any direct drive I've owned (5). I was always told not to.
The more you restrict the air flow, the faster the air moves, carrying away the hot air and replacing with cooler air. The difference between a snail fan and an open face fan. Opening the hood allows the pressure to escape and all that hot air coming off the exhaust manifold and pipes will rise up and cook everything above it. Larger and more efficient fan will help rather than opening the hood. On very hot days here, which happen once or twice a year, we put a fan in front of the vehicle on long jobs to mimick going down the highway.
seattle
We, and many other larger fleet cleaning companies, buy direct drives because they're more reliable and require less maintenance than slide-ins. I don't have any experience with brands other than HydraMaster so can't tell anyone what the differences may be.
The only problem we've had that was a mistake on HM's part was the year they experimented with automotive plastic water fittings. They didn't last.
Otherwise, the issues we've had more recently are all changes made by GM to maximize profit, and that ultimately affected reliability. Doesn't matter what's in the van if the van itself is an issue.
