Large commercial job ?
W
Warren Wallace
I am going to look at a large job that had plastic runners every where. The problem
is of course a sticky residue, this job is new carpet and there are 11 floors.
What would you use to remove sticky residue?
Nate The Great
Was that the poly-tack crap? Left down more then 30 days? We use Ultra Dry from Chem Max. It's a bonnet cleaning method/system that always took care of those problems. I know HWE didn't fix it most of the time.
Hoody
Cleaning Professional Gold Member
Steven Hoodlebrink
Bowling Green, Ohio
Years of Experience
21
Website
Visit Website
I'm sure there will be filtration soiling along the edges of the plastic. So you could use a neutral prespray boosted with a citrus. Scrub it in and rinse.
Joel D
i just did one
i just used my regular commercial prespray with a little extra citrusolve a floor machine and red pad. took right out
Warren we boosted Ultra Pac with citrus booster and used the Cimex to break it up then extracted.
Tried it without the Cimex and it was still sticky.
The Cimex is the key or similar aggitation.
Chris A
all the above and cut your wanding speed about in half on the affected areas.
sweendogg
David Sweeney
You could also use the slightly cheaper combo of Grandslam and Citrusforce ASD from Jon don ( same exact products as Chavez )
W
Warren Wallace
Thanks guys this is brand new carpet looking at it tomorrow.
sweendogg
David Sweeney
If it wasn't loaded up with construction dust, I'd say use a product like Snake Oil or Releasit and encap the stuff.
