Encapsulation vs HWE
speaking of which...
Check your jets, I wonder if they're clogged. With only 6flow, you need no blockage. I've never had streaking on berber. That doesn't make any sense. I bet you looked cute buffing that carpet with those reusable diapers
thats not "jet" streaking, its 12" wand streaking...
600 psi @ 6 flow and MEGA prespray
You're missing the point Matt.
To fool yourself and your clients into to believing that neglected carpet can be cleaned in one visit is short sighted and damaging to your reputation in the not so long run
If you tell the client what it's going to take to get the best results (and the berber looked f'n AMAZING) and that a second , short, visit will be part of the process, they get it.
and yes you wick carpet, even with your 650, all the time and they either don't see it or don't want to call you back because you're so nice...
Whose gonna get the last word? Anybody that’s been cleaning carpet for more 3 minutes knows that 99% of landlords ain’t gonna pay for multiple visits!! Don’t care what the process is. “Can you get me one more time”?
You need to have a 100 mesh filter before your trigger valve. Get rid of the ones on the v-jets. The larger ones on t-jets are ok, easy to spin off and clean.
I do have that setup. when the trigger valve starts to wear out, that's when they start clogging up
Reactions: steve_64
I'm not sure what the trigger valve wearing out has to do with the jets clogging, unless an o-ring disintegrates. I use 4 1.5 vee jets on my Mach 12 and my Westpak @inch wand for a 6 flow and have very few problems. When i first got the Mach 12, it had those tiny filter check valves on the jets. They were a major pita.
bob vawter
Grassy Knoller
bob vawter
When the O-rings deteriorate they will plug
Up jets quick and in a hurry...
Most of my jet plug ups WERE little pieces
Of O-ring..
A filter would need to be downstream of the trigger valve to catch debris from valve wear. Typically filters are placed upstream of the valve.
Of O-ring..
Thats one of the reasons that i remove those little check valve filters. When o-rings start going bad, your wand will drip and force to put in a rebuild kit. Hopefully you do it before they start disintegrating.
Reactions: steve_64
That's actually a good idea Lee. On some of my wands that would be an easy fix.
flush sol line before hooking to wand .
Store in the van with wand head/jets up
and you'll get 700-1000 hours before a jet fouls
side note, you're an idiot if you blow 600psi on berbers or low loop com
and if on the trigger on the forward stroke, you're an even bigger idiot.
I can help cure ignorance
but can't make the blind see
Ignorance pure ignorance..
What's showing harder right now, your mullet or you're not giving a shit about really removing soil
  • Sad
Reactions: Lee Stockwell
Let's know what's showing harder right now your mullet or you're not giving a shit about really removing soil
yeah sure, Mike
slow the triggered back stroke down ...to a crawl when needed.
Carpets need flushed , not pressure washed
"but by-golly gee-wiz, we been doing it that wrong way for 40 years "
That's OK, it's made guys like RickyGee rich and famous
