With a Cimex it's actually quite surprising the rate as to which 5 gallons gets left behind on a glue down. Conditions dictate but most dirty carpets use about a half gallon per 100 ft
I try my best to get to the speed that just prevents the foam spittle. On my dry passes I tap tap tap the trigger just enough to keep the pads lubed, maybe two taps in a 2 ft pass.
Do any of you guys use an OP enough to be able to compare it's juice use to a Cimex?
