- Feb 4, 2016
- Name
- Matt w.
To replace the oil cooler on the air cooled machines:
www.griggslawnandtractor.net
With this heat exchanger to heat the water and cool down the oil much faster
www.toolots.com
Or this oil cooler
www.mrcool.us
Or just adding this feature, instead of replacing it might be all that's needed
More reliable heat and a cooler engine for longer life seems like something that needs to be tested. It just needs to be plumbed where cool water needs to be the first entry into that heat exchanger, then enters in the water box, then the water pump, then the exhaust heat exchanger.
With that setup, the theory suggests that cool water interacting with the engine oil should cool the oil down faster than room temperature air outside, giving longer life to the engine.
Is any of the big wig manufacturers lurking on here to prove this theory wrong? Or would this make the engine last longer and help the smaller machines perform better which would hurt your sales goals?
New Kohler OEM Oil Cooler Kit 5475521 5475521-S
New Kohler OEM Oil Cooler Kit 5475521 5475521-S We Have The kohler Parts Needed With Low Prices
Toolots, Inc. - Reliable Equipment Fast.
Toolots.com is a one-of-a-kind international B2B online marketplace for factory direct industrial equipment, parts and supplies.
Or this oil cooler
63831A3 Mercruiser Engine Oil Cooler
63831A3 Mercruiser Engine Oil Cooler Offered is our replacement for the 63831A3 Mercruiser Engine Oil Cooler. This part also has a finish equivalent to the OEM that is color matched to what the OEM uses on this part. A big improvement on the paint that is commonly used in the aftermarket. It...
