Tip Blooming Special
FB7777
Oh but what powerful selling prowess he possesses
He's influenced more broke dicks to spend their last dime on $800 fans and $2000 wands than any other in this racket
Mad skills
While most of the time they are useful tools, a sales master can not teach the unwashed to use them correctly or on a consistent basis nor school then on not being a close talking creep in the home
10 inches just doesn't allow decent production. It will do the same as the 15 but much slower. On commercial it does look like a toy just due to the vast size of the cleaning space. You probably need both if you clean a lot pits.
Of course it's for homes, goober..
The Golden Boy is right about 1 thing: The 10inch crb...you might as well have an Orek buffer.
:eekk: You can't be serious? Or either you have never used an oreck lol
More speculation..
Yes I've used the virtually worthless OO.
How wide is your vacuum or wand?
FB7777
A 10 CRB seems fine for residential
Especially when you're focusing on traffic lanes
If a place is trashed I'm busting out RV brush head
Reactions: Mike Pailliotet
All speculation.
We have them all.
10" is KING.
Here’s why!
If you have employees?
They will pull the mighty 10 inch out all day every day even if your not looking!
And unless you have one dont speculate about its size!
It has feeling too!
That’s why Mikey Begged Me To Comeback. Watch the traffic here to Double or Triple I’m A Legend In This Industry.
Golden Boy
So far i'm back to Aug 26th 2014 on your posts. Trying to get a bead on you. Very entertaining so far.
Golden Boy
Ya you and me both legends in are own backyards! Hahahahaha
I still like the top
25 though based of mathematical genius and who ever went to a fest that year!
Here’s something else!
I have one other lead tech besides me!
My son left for Northrop.
We have two helpers, primarily they vacuum, and scrub with the 10 inch crb.
So vacuum boy goes in hits all the areas while setting up wall guards.
Me or Phil setup the machine and stage fans.
The start pre spraying, I usually pre spray up to 4-5 areas at a time.
As soon as I start pre spraying crb boy use either white it brown brush depending on what the carpet needs.
I want them spending as much time crb’ing as they do vacuuming maybe more.
Carpet pile is lifted better, wand rinsing is easier.
Customers are blown away at how much hair it digs out.
And with two guys I can knock out 5 hall steps in usually two hours start to finish.
By myself 3 hours if I’m lucky!
Reactions: Russ T.
Nampa Carpet Cleaning
Todd
The King !!!!
Reactions: BIG WOOD and FB7777
DAT
Bill Cheryl
Yeah i dont bring 175 into home because it's too heavy. 10" is all i need to clean trash rentals..never fails... only time i break out 175 is berber...
Prespray, crb, dwell, crb some more, extract. Carpets are as clean as the best of you guys can clean, and im a porty guy. All thanks to CRB.
Hail CRB!
Reactions: Nomad74 and SamIam
Someday when you get a truck now you'll laugh about what a s***** job you did with that portable...
I have a truck, I have a porty, I don't do shitty jobs with either.
Reactions: DAT
You don't see a difference in results on heavy soil?
Only in the time it takes to remove it. The porty can take a little longer but keep in mind, I am still cleaning at 500 psi and very powerful vacuum. Maybe not quite as powerful as a TM but not too far off. When I add in a crb or rotovac, there is no difference in quality. I prefer the truck of course but when I have to use a portable, we take steps to keep our quality consistent. My first machine when I started my business was a 60 psi portable with a cylindrical power brush. I use to take work away from truckmounts.
Austin Willoughby
Austin Willoughby
I can say I started with a porty and had just as good results as my TM except it took twice as long and the big difference isn't the PSI its the GPM and flow rate also the Vaccum. I use to recover 5 maybe 10 gallons a standard size room and with the TM I'm probably around 20 to 30 or more gallons a room its the flushing ability I think that's the difference the deep clean. Plus 2 3 stage vacs is probably 150-200cfm realistically and the TM is closer to 400 huge difference! I'd never go back to my porty loved it but TM is king. I can see using the porty in certain scenarios.....
What wand and what hose size and length?
25-150 feet of hose and 1.5 or 2 inch wand or zipper or rotovac or whatever. At 150 feet of vac hose you notice the difference but still more powerful than a standard porty.
Reactions: vibra-vacster
DAT
Bill Cheryl
I don't do s***** jobs... I have too much pride. My portable is an excellent purchase. Just did a small job ,a recliner, with my new tool. Absolutely amazing. In fact, i want try the new 1.5 devWand with my porty and Power burst. i bet ill do a bad ass job. The only difference is time..
don't you do house cleaning too?
you'll clean a toilet but have "too much pride" to clean dirty carpet?
dude, you're in the wrong biz......
I'm positive you do the best possible.
But the best possible is not doable with a portable when things get.....shitty.
Sustained heat and high flow being the shit kickers that no normal portable can equal.
You'll see.
Reactions: DAT
