Recommended Portable Extractor to start off a business
Ozzy Lucena
Ozzy Lucena
Hi All,
I am planning on starting a Carpet cleaning business in Australia
Could you please give me some advice on which machine to buy? my budget is $4,000 bucks!
Thank you in Advance!
Something similar to the PEX 500. It’s Quite, and easy to maneuver. It has high and low heat and decent suction. It’s not bad loading and unloading from a van with one person. I bought mine for 32 - $3600 last year. See, I answered his specific question🤷🏼‍♂️
Hi All,
Machines over there are 220-240 volt. Here they are 110-120 volt. If this is going to be your only machine, you need to consider how you are going to load and unload. How to get it up stairs. You always want as much power and capacity you can get but more power means more weight. There are some good Australian sites you can research. Take your time and try before you buy.
Pretty much what I would tell anyone here.....If you end up with something as heavy as a refrigerator, you need to think through if you'll be working alone, will need a ramp, how your homes are laid out in your region with steps, etc.
Performance doesn't matter if you can't move it without injury your back.
I agree!! If, he can get something similar to what I said with Aussie configuration, that would be the ticket! Good advice Ron!
AlienAgent
Joe Gingerich
Buy a used one for $1000 or less and use the other $3k for other business related costs. You can always upgrade later when your business starts to take off. And if it doesn’t work out, as so many carpet cleaning startups do, you can reclaim your lost capital easily.
Ozzy Lucena
Ozzy Lucena
Thank you so much for your advice!
Ozzy Lucena
Ozzy Lucena
What's available (and supported by a dealer) there? 240 (and 50 cycle) units aren't sold here, and you want something that has parts near by if you're depending on it.
If you've seen something you like, Ross should be able to give you a worthy opinion of it.
Thanks for your advice mate!!!
Ozzy Lucena
Ozzy Lucena
wise advice mate! thank you
Reactions: AlienAgent
Most of us are full of crap!!
not me
todg
Michael Marcus
Do they have carpets in Australia? I thought you folks walk in dirt and mud? Who knew?
Willy P
Willy P
Im looking forward to checking this unit out in May in FL
Nothing new. Pumptec or a cat 1xp. Both last about a year under normal use, dual 3 stages in series if you can run just one and 1700 watts would be good with another 1700 watts to get serious heat. The only innovative thing that I've seen over my years that really impressed me was the perfect heat by power flight with the little coil exchangers over the vac motors to preheat the water before hitting the inline heater. The rest of the machine was poorly designed but the water was hot.
