Pump Clutch
Farenheit251
When cooling down my machine I noticed the pump clicking off and on. Cat 290 w/3000 hrs. I'm assuming the pump clutch is going bad. Sound right? Is the clutch part of the pulley where I just replace the whole thing.
A brief tutorial on pump clutches would be much appreciated.
when I replaced mine it came as an entire assembly...pulley and clutch......
GeneMiller
gene miller
could also be a loose wire. when i replaced mine you had to buy the whole assembly.
Gene
Farenheit251
Thanks, I was hoping it was all one seems easier to replace. I did play with the wires and it appears to be working now but tomorrow will tell.
Shane T
Shane Tiegs
I got a new clutch for my Cat 340 from Windtrax. I think it was under $200 with shipping.
John Watson
Ronnie, My JEM shaft drive is an 88 model the Original clutch was replaced in 2003, It still works perfectly, changed from twin belt drive when we switched the unit for its 4th van and hooked up the new vans serpintine belt system. One belt set up has worked flawlessly for the past 6 -7 years..
Ron Werner
Ron Werner
gee, been years since I've heard of a Jem. What size blower is on that?
I was thinking of driving a roots 59 with an electric clutch
you have to engage the clutch before you bring the blower all the way up and disengage it after you bring the blower all the way down or they will spin the bolt out that holds it all on........isn't that right Marty......
Ron Werner
Ron Werner
I figured that would just make sense. Trying to engage a clutch when its revved up would be disasterous. Be like popping a clutch
John Watson
Ronnie, I believe mine is a 4M on the Jem, but I have #5 blowwers on a Steam Vac system and a Turbo Tec Shaft Drive that Claude designed and both work well with an elec clutch.
I start the system at idol then speed eng up for what we are doing,
Idle for cleaning uph lower psi to 300
1800 for carpets and psi set at 800.
