Other than Amtex..
T Monahan
Ann Arbor, MI
Tom Monahan
FYI: I have a low hour demo ETM from MYTEE available. It is impressive! That is why Centrum Force is a distributor. Rug shops should have one for this and that stuff. (Private message for unadvertised cost below MSRP for MB Folk for new things too)
I'd get a TCS propane with a waste tank attached to the same wheel frame, with a very small waste tank having an APO attached to the tank so you could run the dump hose to the janitor's closet.
I'm sure TCS could custom make a model like that in no time.
That's one of his thoughts prior to talking to me
I think that's his best route. TCS models are very slim and would be easier to push around
A planet far far away
I wouldn't fook around with off beat brands. I'd have a cart built for a Rage that it can be bolt down on to. Charlie was bragging on how much he loves his Rage and the heat it produces. All together it couldn't weigh more than the bigger lawn mowers. Get a trailer and winch it up and strap her down for transit. Roll her off to use.
Better yet pull it with an ATV, have a hitch on each side to hook up to. :biggrin:
Reactions: DAT and Jimmy L
I’ve heard the same feedback about the rage compared to the 370
Mikey barked at me when I said that
Try putting a small TM in a self powered trailer. You disconnect from the truck and power the trailer down the sidewalk right to a buildings front door. Battery operated electric drive trailer.
