Just call me Molly.
Greenie said:
danielc said:
Do they really want $400 for that vibrating tool? Is it that good?
that's a top of line professional tool, Greenie
all Fein tools are.
it's not really a "vibrating" tool.
It's a short quick saw stoke
Dremel has a grout bit and attachment for the regular dremel tool.
They also came out with a new multi tool similar to the Fein
(but MUCH less power and durability)
Other tub done yesterday (notice the proper technique of before and afters)
and some foreplay for Vince.
and a the promised chimp's eye view of Grout Perfect in action
Oh, and keep some Lime A Way Gel on the truck if you want to be a maid.
It works where Restore does not.
Blue Monarch
Dirk Wingrove
I've never seen the painters tape used to make perfect caulk lines. Nice.
Is it painters tape, or that other stuff you have cut in half?
Goldenboy
Mike Waldron
I do a horrible job when I have to caulk. What is the easiest caulk to use? Whats the trick to gettin it smooth and lookin nice? How do you get the tape lines straight? Where do you get the lime away gel?
Golden Boy
Dont use Caulk, use GE Silicone 2.
Good lord Waldo, I have to tell you how to put tape on straight?
Blue Monarch
Dirk Wingrove
Gee Waldo, as much as I hear you talking about caulk :shock: , I figured you new it like the back of your hand.
Goldenboy
Mike Waldron
Yes I have used the blue tape before. i have a bathroom I painted to prove I can not tape straight. If I need something caulked I call a plumber.
Golden Boy
clean image
so Molly,
no seam sealer, caulk for the spout or valve discussion plate?
ya know water's gettin in there
having enough trouble with straight lines with blue tape that circles are out out of the question?
looks like you use a caulk gun to apply, inconsistant bead, i like the smaller tubes, exact razor cut the tip, apply near perfect, and use "a spray" sold at lowes, to smooth, this product, like another i got at coverings, will not allow the silicone to stick to the tile. so use carefully
carl
clean image said:
so Molly,
carl
Spout and plate are getting replaced.
I'll try the tubes, thanks!
safeclean
Instead of using the blue tape try and use a popsical stick (paddle pop stick) that way all you have to do is cut the right size whole run your bead and than use the stick to tool with works very well for me as I use to use the blue tape all the time but no need to anymore.
Craig
alazo1
What happened to just saliva and your finger?. It does ok if the caulk is not too sticky.
Albert
safeclean
The finger works well but you get a better uniform line with a paddle pop stick I still use my finger for the corners though and neutral cleaner not saliva yuk.
Craig
daniel@procarpet
Great job. Could you explain briefly how you restored the tile? I have been turning down jobs because simply cleaning a shower stall does not get satisfactory results for me. What do you do if the grout is chipped or stained?
Thanks
No "restoration" was doe to the tile other than cleaning.
Grout is easily repaired if stained or missing. Dig out the damaged stuff, mix up some fresh using a acrylic additive/modifier instead of water.
miksar
Mike Fent
Mikey, about how much area would one of those bottles of cs cover, I looked on gs website, couldn't find any info. Thx
Gary T
To answer a few questions. Like concrete, grout does not stick to grout. I use an additive and remove a minimum of 2/3 the depth of the grout line as advised by the TCNA.
Don't use the Dremel rotary to remove grout. It makes a dusty mess due to the speed of the tool. Dremel just released a tool very similar to the Fein multimaster. There are are a few guys on DirtyGrout testing them. They should do fine if they are not used daily and only for repairs, not complete regrouts, as I don't believe they are as durable as the Feins. They run about $100.
I like Laticrete Latasil 100% silicone for caulking ANYTHING. GE is a very distant 2nd best. Do not use DAP, it stinks, and is very difficult do use and clean up and really is not a good caulk. Do not use latex, acrylic, or siliconized latex. They will all crack and mildew. If you will be caulking showers, use the best possible 100% silicone caulk.
Where can I find the Laticrete Latasil and have you tried Silkausa concrete bonder/acrylic additive in one?
Scott S.
Scott
This Thread is awsome. Never thought about doing bathrooms to much. and seeing mikey on his knees priceless.
Scott S.
Scott
mikey what chems are you using to clean the tubs? tile and gout cleaner also?
Gary T
I get Latasil caulk from Century Tile here in Il. Not sure who carries it out there. Floorlife.com has it. I usually use Laticrete Bonding Admix. Really any grout admix will work.
Have an assortment of acids and alks on hand. Lots of stuff at your hardware store works fine.
Most home owners are just too lazy or old to roll up their sleeves and scrub.
Make sure to have Magic Al's non acid soap scum remover on hand for stone stalls.
