Installing new tackless strip on old concrete.
ACE
I was tearing out moldy tactless strip yesterday for a property manager that didn’t want to pay for fans and dehus. I ended up using pad adhesive on the tactless strips just to get the job done. I have never been able to hammer in tackless or brass strips into old concrete, it just chips away. Will using a 20 oz hammer make a big difference? I usually use hot glue but if the concrete is damp at all hot glue is useless. What other fast setting adhesive would work well in a damp environment that is encountered in WDR?
sweendogg
David Sweeney
The nails in concrete tackless strip is only really meant to tack into place until you double nail the stuff. On all concrete we only hit the nail once initially to set the nail with a 16oz to 20 oz hammer. We then come back behind and using a hamme drill, drill an 1/8 inch hole about every 8 inches and at each end of strip. We then renail with 3/4 inch maze nails. After these nails have been sunk intothe concrete, we go back and burry the rest of the nail head that comes with the strip. If the floor as a radiant heat or other speaciel circumstances, we will use liquid nails, or this product:
http://www.tools4flooring.com/chemrex-c ... -1308.html
However if we have to glue the strip, we always schedule a day or 2 for drying.
Here is teh tacks trip we use.
http://www.halexcorp.com/carpet_tack_strip_3.shtml
you may also want to try this in really wet area or areas prone to moisture:
http://www.halexcorp.com/carpet_tack_strip_5.shtml
KevinD
Kevin Dumas
Hammer drill and nails here also. Never messed with the rest of the stuff.
I purchase nails from my supplier that are slightly larger in diameter than the normal tack strip nail. I set the original nails in place with a slight tap of a 20 oz hammer, but not fully set them. Then, I come back and nail the strip in place with the larger nails and follow up by setting the original nails last.
Harry Myers
Harry Myers
If you have a problem with nailing into concrete I would use some chem-rex sold at a carpet tool place. It is a urethane adhesive and moisture allows for better curing .
handdi
Randy
make sure ya get alum nails when drillin hit them in and they expand carpet places have them
Harry Myers
Harry Myers
Here is another option . Kool slide sticks that you use with the kool glide seam tape is excellent for holding tackless. They are making green kool glide sticks for tackless . I would not buy them now they are not perfected.The regular kool glide work great . Once again another urethane adhesive but in hot melt form.
John Watson
dats OK.. I believe I am a bit of both, I'm part square head so my ansestors have mastered putting square pegs in round holes for centuries. My Grand father said it was while they were perfecting the craft, all the screw ups became swedes...
Reactions: Harry Myers
sweendogg
David Sweeney
We use to use aluminium drive nails but we still could pop aluminum on very long drives, the maze nails hold alot better than the aluminium's did.
The idea is to be able to secure the strip while you are there. Not to have to wait hours on glue to dry.
Harry Myers
Harry Myers
ACE: What other fast setting adhesive would work well in a damp environment that is encountered in WDR?
Both methods I gave you dont have to wait Chem rex you could powerstretch 1/2 hour after applied and the kool glide sticks you can stretch when the glue cools down. If you even want something faster the chem rex , you can use bondo.
L
lancehollister
The nails supplied in the tack strip dont work well on concrete. I would replace with quailty concrete nails and the smaller the better. You want to use a min. 20 oz hammer and a hammer bar is recomended. Then you want 2 or 3 solid hits at the most to sink the nail.
Weird ... I've found that replacing them with a slightly larger diameter nail bites the concrete better. Next time I'm at the supply shop I'll buy some smaller ones and see.
L
lancehollister
The nails i use are slightly fatter. By little i mean 1/4 inch or so. Just long enough to sink in 2 or 3 solid hits.
ACE
Wow,
Thanks for all the ideas! I will try a few of them out on my basement; which is a small unfinished space 8 x 12 and always damp. I felt like a real hack on the job the other day, next time I’ll be ready for this situation.
