how many of you dudes do shower work?
Im covered head to toe in Magic Als.
for two shower stalls @ $1100 Ill wear a maid outfit.
There's an idea to get people to show up for the next MF.
Don't do them, but the more I look into stone cleaning, color sealing and stuff like this, the more I would like to do more jobs without having the TM running all day.
I just don't want to look like or be considered a "cleaning lady".
typically...
razor blade as much soap scum off all flat surfaces as possible.
Spray down acid cleaner or non acid soap scum remover and scrub
Rinse with shower head or pressure line
Alkaline spray and scrub, rinse again with Cobra hand tool
Dry
Remove damaged/rotted joint between tub and wall if needed.
Polish tub if needed with Magic Als, diamonds, steel wool. etc..
Seal grout/stone Leave fan overnight
Return next day to replace silicone or grout.
