Had an eye opening experience today..
Took the 14/2 out to clean a empty community rm at the base.
Felt like i was driving a 1967 Cadillac in comparison to my new VW Bus...
Strange how we get use to things and actions...
What's a 14-2?
can be used for lights
everything else should be 12/2
LTA
Last week we used the 12 1.5 for a couple days. Drying was an issue on one job but it sure was faster and easier.
Switched back to the 14 2 and it was amazing how much drier it leaves the carpet.
Reactions: Wand Slinger
Wand Slinger
Christopher Paulhamus
The 14/2 auction coming soon?
'67 Caddies fetch a good coin.
So how long did the carpets take to dry with the 12 compared to the 14? How did you do the testing?
Lyman
Lyman
The last two weeks, I went back to my 14/2/18 ti. Been loving it...
OK so I got a question that (may) be pertinent here
Got an old Prochem 3 jet 1.5" tube 6 flow wand - no glide and slots are close to each other so it gives off this high pitched whine.
Also have a Prochem Quad 4 jet 2" tube 8 flow wand (hate 1.5 jets that clog) - no glides and the slots are wide apart so you don't hear that vacuum whoosh
both are about 11" wide
Assuming I am using the same TM and cleaning/dry strokes, which will produce the best cleaning results and fastest drying times?
Also I have been using the 3 jet 6 flow like forever because it is so light so if I switch to the Quad at 8 flow would I notice much difference in water usage?
DAT
Bill Cheryl
Would that pulverize carpets using 24 flow?
25% more water usage, some offset by potentially better extraction with the 2 inch wand.
