as opposed to wrapping the paint filter around the bird net ring....
All the crud goes further back/down the bag..
That’s the way I do it on the silver bullet. But I only use the paint filter. No basketView attachment 122177
Tom's uses a mesh " basket", which I guess could be eliminated this way..That’s the way I do it on the silver bullet. But I only use the paint filter. No basket
If you vacuum, which I know you do, the basket is unnecessary.Tom's uses a mesh " basket", which I guess could be eliminated this way..
I'll try it tomorrow
My wand doesn't over spray.You’re wrong, as usual.
That the only way some other work periodView attachment 122177
The paint filter can rip if not supportedTom's uses a mesh " basket", which I guess could be eliminated this way..
Very small percentage of the time. You can guarantee it going to rip if you don’t vacuum or use the same paint filter on multiple jobs. Don’t be a hack or a cheap ass and you’ll have nothing to worry about.The paint filter can rip if not supported
Yes. The 2 inch hose hickey on my right butt cheek without the basket was more pronounced, versus 2 inch hose hickey on my left butt cheek with the basket.But is there a noticeable improvement in vacuum minus the bag or screen?
Did you perform a controlled test in your living room or is you speculatin?
Mainly because I do not waste my life away running a CRBWhy use an inline filter?
No matter how good the filter is, it still negatively impacts airflow.
I just let the little bit of debris left after I CRB and vacuum go right into the waste tank. It all comes out just fine when I dump it. I clean it once every couple weeks.
Thanks for making the caseSo, all that gunk comes out of my waste tank, whether I CRB or not.
We didn't use one when we had the Aerotek and vortex because of the round convex bottom as you said everything would truly flush out but with the square tank of the 370 being right behind my head where I got to smell all that bacteria I'd rather filter it out but I can get away with it here in the petrified ForestSo, all that gunk comes out of my waste tank, whether I CRB or not.
I get that, but on smaller machines, we don’t have airflow to waste. The moment that filter starts collecting debris, you lose it.We didn't use one when we had the Aerotek and vortex because of the round convex bottom as you said everything would truly flush out but with the square tank of the 370 being right behind my head where I got to smell all that bacteria I'd rather filter it out but I can get away with it here in the petrified Forest
Its all them damn trees fault...I get that, but on smaller machines, we don’t have airflow to waste. The moment that filter starts collecting debris, you lose it.
Aka: lifeIts all them damn trees fault...
loose some of that capability by removing the mesh basket
If I remember correctly, the mesh basket is smaller than the paint filter itself, so if it’s removed, that leads more room for the paint filter to catch debris.Plz explain your theory.
correctIf I remember correctly, the mesh basket is smaller than the paint filter itself, so if it’s removed, that leads more room for the paint filter to catch debris.
