Butler System detergent dilution
  • Thread starter Andrew from Simply Clean
  • Start date
No
But in a board Far far away that was once a topic of endless ( and pointless) discussion.
But remember, there are those here that did not live in those days of yore when there was an adminstrator who made himself an easy target for good natured (and not so good natured) abuse, and there were more than a few very unusual characters on the loose.
So for those who have more recently entered the industry, its right to give them a direct answer.
Just imagine if Fred C had run that board instead of the individual that did?
Raft? You'd have needed an ocean liner........
lta
Reactions: hogjowl
ruff
Ofer Kolton
Butler's original metering is only for liquid based detergents and is designed for much finer (size wise) liquid.
I had it removed and have the GPH one installed which allows me to use powder based detergent without issues.
Yes. Butler's metering system is less, shall we call it "refined". It works but is not as accurate. In my set up it seems to draw a lot more than my previous CDS or Pro- 1200. I just dilute it a lot more and understand that it is not a fine instrument.
We (Butlerites) always go for beauty over substance. Every single time. That's how we know that we belong here. :winky:
Mark Saiger
Mr Happy!
Mark Saiger
For the saiger rinse would it effect the prespray if I have it running through the line to the hydroforce sprayer? Like would it neutralize the prespray before it hits the carpet? Just curious
Not enough to run out to the van each time....we keep it on except with using our P-Lime-Zyme...Then shut it off while applying and turn back on to clean
ruff
Ofer Kolton
How easy was it to make the switch?
I didn't do it. When I bought the machine they asked me what kind of detergents I use (powder mostly). It's just replacing the mechanism from a needle point style to the other. It took them 10 minutes.
Reactions: Donwand
They didn't give us a choice they said to have fewer problems use liquid.
ruff
Ofer Kolton
I think crazy George may be able to help you after all.
.... and in all facets of your life.
Ask for the total make over special.
I think his girlfriend has a better chance of keeping my attention. Plus her seminar was cheaper! 😁
Reactions: ruff
