- Apr 17, 2009
- Name
- Kenny Hayes
Where I'm at, probably very few and I suspect it will be the same in warm weather places. In cold weather climates, you will see many more using VLM just because you don't have to worry about your truck mount freezing. As Sam was saying, if you have both, often hwe is quicker and more efficient.Your probably right how many of them use it on Residential
Well as a start up yes it cheaper, but for guy with equipment to do both....
It's not easier or faster in a residential setting.
Let's see it in action on residential carpet.
I'll have to dig. I have other videos, even some with it being run with 2 hands. But you can see here how easy the Echo is to use.Let's see it in action on residential carpet.
What differentiates it from John G’s old machines?Looks similar. I have two of John’s machines. A Profit and a Champ. What I found was fastest in big commercial buildings was a Mytee variable speed rotary with 3 gallon solution tank and front wide spray nozzle it has a lever on the left side handle to spray cleaning solution. You can also angle the spray tip in you want to walk it sideways..slower speeds make the pads really hook up.Built out of necessity but built on purpose. More head weight and more agitation with 1 1/2 inch oscillation. Yup, that's the biggest. But it had to be easy to use, so, wheels up. And the biggest problem to solve, up stairs!! Love op machines but why are they so heavy going up stairs? My gosh!! So I designed this machine with that in mind and amazingly the Echo can be pulled up stairs with one hand. It's really that easy, a residential carpet cleaners dream. It's an absolute beast in cleaning with less cleaning solution and easier to manuever than other machines I've built or used. Never built a machine that runs this smooth, where's all the vibration? Again, built that way on purpose. View attachment 131901View attachment 131902View attachment 131903
Buying an ATP meter to measure the bacteria count before and after cleaning made me move away from hot water extraction. Why? Bacteria live in our carpets and eat our flaked off dead skin. They build their colony’s in places where there is more food. When you blast a carpet with Hot water, you blow the bacteria present into the backing where the multiply in the presence of ample food (our dead skin) and moisture. The bacteria population grows rapidly in the presence both food and water…I am amazed at how quickly and easily I move in and out of a home now that I am using a truckmount. I still take my time with vacuuming and all the works. It just sets up and cleans so darn well. I can only imagine when I get real heat on that thing soon. Personally I feel way more confident and valuable going to each job now.
As you know I've built John's machines for over 10 years and worked with him since the days of the Profit, cm and the Conquerer. I designed the Echo from some of those older ideas, the 15 inch pad driver for better balance, wheels up for better maneuvering around anything. But I gave it a larger oscillation and designed it to be lighter than the older ones for the purpose of going up stairs. My goal was 90 pounds because I knew it would cancel most of the vibration at the handle making it smoother and easier to use even with the larger oscillation. And because its only 90 pounds and a couple other modifications it can be pulled up stairs with one hand. Thats never happened before with a Trinity.What differentiates it from John G’s old machines?Looks similar. I have two of John’s machines. A Profit and a Champ. What I found was fastest in big commercial buildings was a Mytee variable speed rotary with 3 gallon solution tank and front wide spray nozzle it has a lever on the left side handle to spray cleaning solution. You can also angle the spray tip in you want to walk it sideways..slower speeds make the pads really hook up.
I’m glad I never hot water extract mall carpet. My cleaning might give a kid hepatitis or aidsBuying an ATP meter to measure the bacteria count before and after cleaning made me move away from hot water extraction. Why? Bacteria live in our carpets and eat our flaked off dead skin. They build their colony’s in places where there is more food. When you blast a carpet with Hot water, you blow the bacteria present into the backing where the multiply in the presence of ample food (our dead skin) and moisture. The bacteria population grows rapidly in the presence both food and water…
The threshold for a clean environment is 200 cfu ( Colony forming units) of bacteria. Anything higher is unclean. I used to clean the carpet areas in a big Mall down in Daly City. The swabs taken before cleaning on the toys in the play area averaged 700 cfu. Seriously dirty. A woman complained that her boy got sick every time he went to the play area in the mall. I usually tested 4 different areas. After cleaning with a low moisture nano partical cleaner, the highest reading I could get on my atp meter was was 91 cfu, 200 Cfu being the thredjold for clean. Rent or borrow an ATP meter… it will tell you how present the enemy is that you can’t see…
That would probably test better.Complete BS!
I bet whoever took all these tests after HWE, went over that carpet with a 2flow wand moving it faster than a logger hand-sawing a log
Complete BS!
If they don’t know how to properly use a wand set at the specific flow and pressure, yes over wetting is a big problem.Entirely possible but does flow play the largest part in over wetting?
Unbalanced set-ups
Clogged filters
Leaky tanks
Poor wand technique
Over application of pre-spray
No glide...
Greenie used to say, You can't over-wet carpet, only under-dry it..
I suppose that true with area rugs, but if the subfloors gets wet, it's gonna take a while unless you lift the carpet.
Ask any restoration pro why...
LOOKS GOOD , Charles. Nice job. What size driver ?Built out of necessity but built on purpose. More head weight and more agitation with 1 1/2 inch oscillation. Yup, that's the biggest. But it had to be easy to use, so, wheels up. And the biggest problem to solve, up stairs!! Love op machines but why are they so heavy going up stairs? My gosh!! So I designed this machine with that in mind and amazingly the Echo can be pulled up stairs with one hand. It's really that easy, a residential carpet cleaners dream. It's an absolute beast in cleaning with less cleaning solution and easier to manuever than other machines I've built or used. Never built a machine that runs this smooth, where's all the vibration? Again, built that way on purpose. View attachment 131901View attachment 131902View attachment 131903
Hey Randy. Intentionally I used a 15 inch pad driver because with the sizes we've used over the years, 15 was always so smooth. With all the agitation, including the tamping, there is almost no vibration at the handle grips. Thats a big deal with oscillating machines.LOOKS GOOD , Charles. Nice job. What size driver ?
Yes, the seating areas though out the mall varied somewhat… I also tested hard surfaces just to see…the arms of most seating areas in the mall were pretty contaminated. But their janitorial crew cleaned them nightly after hours…Can you be more specific to what this actually means?
Are you referring to the pres praying process where many cleaners use 300 to 500psi to heavily "soak" the carpet fibers, or..
The wand rinsing process at usually the same psi..
Did you test behind your work, and or others?
Dud chemistry residue come into place?
Slow dry times?
Wand type or wand technique?
Size of truckmount?
And probably most "dangerous" is the fact that a VLM'd carpet dries in a few hours worse case. (with heavily worked coffee stains being the over night exception)
Compared to HWE taking 24 hours at best, typically.
Obsessive cleaners with big trucks, fans, hole Glides and lots of dry strokes can get a carpet dry much quicker, but in a commercial setting, few to none with take the time.
Your example of the kiddie play area was likely filthy and needed excessive wanding. Did you test other area in that mall?
Oh...Most of the Members here at Mikey's Board are ''Old Farts'' set in their ways and very resistant to change
They still think you need to flood carpet with gallons of water to clean them
They refuse to accept it's 2025 and things have changed in the Carpet Cleaning World
I'm trying to EDUCATE them but they HATE ME for that
GOOD LUCK and Welcome to Mikey's Board !!!
Oh...
Deflate the ego.
Gallons of water.
49 yrs in this career field.
An your one of the problems still.
Misinformation as per normal.
You take your SteamwayPro.
Ill ask Jack Mesheau to lend me a Butler for the day.
I will out clean you with ergonomic efficacy.
Out dry you.
An show you why.
My Name is self explanatory...
Furniture
Carpets...
Any time.
An when Im done get on this board.
An tell them all a old Cancer stricken Fart.
Kick yer...
You can’t say that on one side of your mouth and then go trash others with the opposite side of your mouth… that guy is purposefully trolling cleaners here to get some kind of interaction to get his serotonin levels up. I wonder if he would act the same in person!?May I suggest practicing some kindness in your contributions here?
And if that ever stops, I’ll know it’s all a lie.Jodi, I highly doubt you can find any instances of me trashing anyone here or elsewhere in recent times, other than poking fun at Marty.
Why not say that to steamwaypro?May I suggest practicing some kindness in your contributions here?
