Mar 28, 2014 #1 Mike Pailliotet Administrator Joined Oct 6, 2006 Messages 117,258 you only wish you had one of these.. https://www.youtube.com/watch?v=RYps4Wtm4CQ Reactions: dealtimeman
Mar 28, 2014 #2 hogjowl Idiot™ Joined Oct 7, 2006 Messages 50,010 When foam blows out the blower exhaust, you know it's full. Why all the fuss ? Reactions: Mike Pailliotet
Mar 28, 2014 #3 D dgardner Guest Make sure the Kinetico line doesn't flow any air during normal operation. The pressure imbalance will make the sight tube read low.
Mar 28, 2014 #4 A Able 1 Guest Not sure you will be able to see through that in a month.. Well, that's what it would last here before it would be useless. If you would have put a neon floaty ball I would be more impressed.. Must be nice to clean clean carpet. Reactions: GCCLee
Mar 28, 2014 #5 G GCCLee Guest I Dig the sight tubes! Did ya put screens on the in n out side so ya don;t have to fish out any hairballs?
Mar 29, 2014 #6 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,877 Name Jim Martin and it does not bother you the salt water goes into your tank... when they cycle it is a pretty high concentrate of salt........
Mar 29, 2014 #7 Mike Pailliotet Administrator Joined Oct 6, 2006 Messages 117,258 And out it goes within hours.. It's Vladified!!
Mar 29, 2014 #8 Nate The Great Member Joined Mar 29, 2008 Messages 9,756 Name Nate W. I thought Dwayne Oxley had that on some of his machines??
Mar 29, 2014 #9 S Shane Deubell Guest I thought EVERY waste tank had one... How do you know how full it is?
Mar 29, 2014 #10 jwfoulk12 Member Joined Aug 10, 2012 Messages 861 Name Justin Foulk My white magic has one
Mar 29, 2014 #11 knoxclean Supportive Member Joined Dec 10, 2009 Messages 635 Name David Gargan It amazes me that all tm makers don't make it standard to have some type of water level reading. The only tm I owned that had one was my Butlers
Mar 29, 2014 #12 G GCCLee Guest Jim Martin said: and it does not bother you the salt water goes into your tank... when they cycle it is a pretty high concentrate of salt........ Click to expand... Did you taste the water out there? My Gawd lemme tell ya, to dangerous for any kind of containment Period!
Mar 29, 2014 #13 AshleyMckendree Supportive Member Joined Sep 1, 2007 Messages 1,572 Name Ashley Mckendree Mikey, does it have a bright orange floaty ball so you can see the level?
Mar 29, 2014 #14 Mike Pailliotet Administrator Joined Oct 6, 2006 Messages 117,258 No. When I replaced the tube on my Butler I put a Legoman head in to replace the lost ball. this tube is 3 times in diameter than the Butler's, can't imagine not being able to see waste water. Unless of course I was following a Trinity and the waste was as clean as baptism water. Reactions: Mark Saiger, Vincent Feehan, hogjowl and 2 others
