Winterize
SuperiorF
Dec
Role
Years of Experience
1
How do you winterize Blueline Thermalwave? Are there any heaters that work best?
did you not read my reply to this question you asked me in pm?
Crank up your tm.
Suck all the water out of your water box
Fill it up with low -20f temp windshield washer fluid. 5 gallons average
Turn your water pump on
Hook up your solution hose
Open it up to push all the water out of the hose until you see the windshield washer fluid
Put some of the windshield washer fluid in your rinse jug
Prime the chemical pump
Hook up your carpet wand, hydroforce, tile tool, uph tool. Run WW fluid through those as well to protect the trigger valves
Bryce C
DFW
Bryce
Is it true that when running antifreeze through the system... that unless one purges the line to their pressure gauge then that will hold regular water and bust when it it hits freezing temps?
Latest Auctions
