Vortex/AT owners...........
Put new shocks on the UD today.........
the stock shocks that it comes with do not preform or hold up for nothing....
I strong advise you that if you even think they are going out to get them replaced right away............once they get soft they just dump over night....
I was doing research on them knowing mine were going soft and you will not believe some of the damage that my truck took due to the shocks bottoming out and slamming the chaise.....
the part #'s are
37113 for the back
and 37033 for the front.....
these are not stock shocks but much better.......
they will not find this match in any book or cross reference.......
these are heavy duty Monroe shocks and they did a physical match and they went perfect on my truck.....
each shock is $43.99 much better shock for a cheaper price.......
Truck rides and steers much better.....much easier ride....
there is only about 68600 on it......
my mechanic said I should get a easy 100,000 off of these
save these #'s they may help you later.........
Demien
Thanks Jim!!
I'll change mine the first chance I get!!!!!!!
What did your mechanic charge to change them out for you ?
Demien
dealtimeman
Everyday is Saturday.
Michael
must of missed this post.
jim how are your shocks holding up now?
Carpet Cleaning Fool
Think I'll order a set in the AM.
Thanks for the tip.
Shocks have been on my mind lately
shocks are holding up fine..cab does not bottom out any more.....
Chris Muetterties
When I did a search for those numbers they show up as a 37113 Monroe Sensatrac Toyota Tacoma
Does that look right ?
Just crawled under my truck and double checked and the numbers are correct...Monroe Sensatrac heavy duty shocks
