69what's it weigh?
while you're doing the back of the church pews...
Spray SYSTEM you mean.I don't see how it can be any better than the original one if there's no spray jets on it
They used to be as the Wheelers were Gurkink's pet project, but I ran them off.I'm thinking if they were endorsed by the Wheeler bros they would sell more of those overpriced POS.
I'll never use an OP in a residential setting.Spray SYSTEM you mean.
Its better for certain situations BECAUSE of that.
With no onboard sprayer, you have to spray ahead of yourself with a pump up or electric or backpack, thus giving the old cleaning process more dwell time rather than immediate agitation which for residential carpet as a plus.
And with no spray system, there's that word again system, you can maneuver it into tight areas. Much easier.
Think of it as trying to park a pickup truck without a trailer attached, that may help you process this better..
My guy in Scruz is killing it with the meganaires with VLM in residential.
725k in two years...
piranha marketing reely works
You don't understand..
me?
I don't GAS
Good for him and Moniqua
some people will buy anything
I understand your promoting OP, but just another situation where the RotoVac StairPro rises above all.
That being said, why not run a nylon-braided line in tandem with your power cord? Replicate the plumbing&jets from the larger model Trinity''s and feed from a remote pump and solution source.
The same system could be used for regular OP/Buffer machine of your preference, to eliminate the awkward solution tank and prevent spillage when changing pads or cleaning heads.
Which pads?Possibly the best residential VLM machine.
Maneuverability of a rotary, with cleaning depth of an OP.
The reason I haven’t pulled the trigger yet is because I’ve read at least a dozen posts where owners complain about the small motor being overworked with certain pads.
Some scrub pads and microfiber pads with more aggressive scrub strips.Which pads?
I don't know why someone would use ultra aggressive pads in a residential setting that's appropriate for VLM, but whateverSome scrub pads and microfiber pads with more aggressive scrub strips.
Sounds like the carpet tape also has an effect.
The Odyssey is not meant to replace the Phoenix, it's meant to compliment it and to be used alongside to do the lighter soiled sections and tight areas in a home or buisnesses.Some scrub pads and microfiber pads with more aggressive scrub strips.
Even the people who have mentioned certain pads over working the motor still love it.The Odyssey is not meant to replace the Phoenix, it's meant to compliment it and to be used alongside to do the lighter soiled sections and tight areas in a home or buisnesses.
I assume you're reading this over on that anything goes group, where I would imagine the people complaining just stepped up from an oreck orbiter and they're bitching that this thing won't perform like a phoenix that they should have bought
Ive used it at my events with blue micros and the grout brush (which kicks ass) and my only critique is that I need a longer handle.Even the people who have mentioned certain pads over working the motor still love it.
I don’t post in that group anymore, I can’t tolerate groups that promote shitty work.
Think it would be long enough if you were 6-3ish?Ive used it at my events with blue micros and the grout brush (which kicks ass) and my only critique is that I need a longer handle.
I would still add 2 in which I can do for you if you order it from me.Think it would be long enough if you were 6-3ish?
