Suggestions for removing strong VOC smell from concrete slab?
MasterCarpet
Trace
Role
Years of Experience
17
I've got a customer with a large open finished event area. A construction company did some sort of coating removal on the concrete a couple weeks ago. It left a strong solvent type of odor. It's pretty bad. My customer even rinsed it himself with a home carpet cleaner. I don't often use ozone, but I have an ozone machine so I let him borrow it for a few days so he could experiment with it for different durations and see if anything worked. He called me today and said it's still pretty bad. I had suggested to him that if the ozone didn't work, I could try rinsing all the concrete with my tile spinner. So tomorrow I am going to go there. Thinking I'll just prespray with some saiger sauce and bump the heat and psi up and see how it goes. It's not a highly polished concrete or anything, it's just like the type you would see in a garage, and now apparently with no coatings on it. I thought about putting some saiger cide in the prespray. Although he didn't want any more smells in it, I think the smell from saigercide wouldn't really linger. He's going to have some clients to visit here in a week or two so I've got a bit of time to figure something out if it doesn't get the odor out tomorrow. Thanks everyone.
Dwain Ray
Without seeing and just furnishing an educated guess I would probably try a degreaser with a floor buffer and stiff bristled brush vacuum off and thoroughly rinse maybe something as simple as dawn dish soap(youll need defoamer if you use dawn). I would however pre-qualify the job as a fixin someone else's mistake and have no guarantee or okie guarantee ( if it breaks they get to keep all the pieces(for same price) ). Dawn would be my first choice, if you need something stronger maybe step up to a Zep product but i would be hesitant to use products that would add additional smells/ odors . Home depot has several degreaser options in the cleaning products isle and you can unscrew the caps and take a smell before you buy
These things are complicated to solve, but a few things I know about this type of issue might help.
1. Avoid using ozone when dealing with VOC issues. The nature of how ozone works can create new and potentially worse VOC issues when ozone gas interacts with whatever you are dealing with there.
2. Cleaning in the way you are suggesting might help. If you are using a truck mount (most spinner use is with truck mounts, though sometimes high pressure portables are used........DO NOT USE A PORTABLE FOR THIS....it will spread the contaminants in the interior air) you will be removing some of the VOC source material and the truck mount will remove it out of the structure.
3. Skip the deodorizer. It won't help, and it could annoy him when he's already in a state of anxiety.
4. If you own (or have access to) air scrubbers with carbon filters, these will help this situation a great deal. If you don't, then open as many doors and windows as you can and just "airwash" the house as best as possible. If you have several airmovers, set them up blowing IN, not out. It is challenging to exhaust bad odors out, but far easier to introduce large volumes of fresh air in, which should displace the contaminated air.
Do you know what chemical was used to remove the coating? If you can share that, it could help.
MasterCarpet
Trace
Role
Years of Experience
17
Thanks for the response. I didn’t know how well the ozone would work but figured it was worth a shot. Me and him were both researching how to use it safely. We both figured it wouldn’t hurt to try. I’ve only used the machine for personal use a time or two.
I will be using a butler so no worries on the fumes. I also wish that I could’ve gotten the specific chemical that was used, but he isn’t quite sure. There’s a high of 58 here tomorrow, the warmest it’s been in awhile, so it’ll be a good day for me to be able to open up windows and doors and blow air. It’s been so cold recently that the place had to be pretty much closed up the past 2 weeks. Will go at it tomorrow with the spinner and a bit of detergent and see what happens.
Reactions: Jim Pemberton
What has the temperature in that room been since that voc was used?
The first thing I would do is Force off gassing by raising that room temp to 85F, lay down an air scrubber or two, and if possible, create negative air pressure with the exhaust going outside
MasterCarpet
Trace
Role
Years of Experience
17
Well I just wrapped up the job. It was about 2200 sq ft of concrete. Took 6 hrs total but that included getting down and sniffing around a lot identifying where the majority of the smell was coming from. Flushed it really slowly after prepaying sections with Saiger sauce. It’s all brand new. Apparently the construction company poured the concrete then put the 30 day sealer on it. Then when they went to put a polish look coating on it, had a horrible interaction and it was all messed up. So the coating company told them they had to strip it all off. And they did but it left this terrible chemical odor.
I followed the advice above and opened all the doors and set air movers outside blowing inward all day long. I did notice when I went too fast in a section, you could tell there were some jet marks where it was taking off some sort of residue. From getting on my hands and knees I could tell that 80% of th odor is coming from the cuts in the concrete. Where there was some sawdust or othr crap crammed in there that probably soaked up that stripper.
Just left and the smell is much much better. But will see how it is now that it’ll be closed up for a night. I told him if the smell is bad again we should try air scrubbers. Since I don’t own any, I told him I could either order one or two and rent to him. Or he could just buy them himself if he has use for them at other properties. Definitely one of the more interesting/ challenging jobs I’ve ever had. IMG_4996.jpeg
  • Love
Numero Uno
Caesar
Zebruktolite ,hidden under pool table/tables . Five lbs of salt mopped on with very hot water .Let dry clear rinse following day.The salts will adsorb and pull out the solvents escaping...Sound's bizare but work's like a charm very cheaply...The dryer is shearing ,the pod is actually driving odor back in...
