Meat juices and VLM
my UPS store had a box with steaks in it leak and they got a smelly spot on the floor.. that I need to address today, and of course my truck mount is in the shop getting its vinyl
how would you address this with chemistry and an OP machine
Probably pretreat with Saiger's P-Lyme, let dwell at least 1/2 hour. Then hit it with Code Red of Encaps.
Jeff T
Hit with vol. 40, dwell, put down a prespray W/ a pump up, extract W/ spot machine, post spray affected area W/vol 40, VLM as usual.
It’s meat juices. You can’t get away from the fact it’s a biohazard.
Vacaway has a great product called Grease Hawg. Unless Rob has ruined it already.
Reactions: Nomad74
I bet you didn't shower after your morning poop today...
hack
Reactions: Willy P
After I use my CRB to get up all the powdered deodorizer, there was no sign of any staining ,rot, juices, odors or otherwise but I still soaked it in Sager Cide for a half an hour and triple padded the whole place with pretty darn good results, much better than when I hot water'd it the last time
