GM 6.0 engine problem with weak pulley on water pump
JoeClean
Anyone else running a pto on this engine have problems with the water pump pulley breaking? Literally cracking where it attaches to the shaft.
If so, is there a heavier duty or aftermarket water pump with a better pulley available?
You have to change the whole water pump, the pulley is not removable.
I did a google search and found on a performance/racing board they were complaining
of this being a weak spot for that engine.
All I wanted was just a little more lift, the clutch is fine. (Cleanco)
Joe Kelly
