Glide help
  • Thread starter daniel@procarpet
  • Start date
daniel@procarpet
I need to get this hole glide on my 4 jet prochem wand asap. I have heated it and now what should I do? What is the best way to get the glide on?
joe harper
joe harper
Dan, the quad wand is the HARDEST to get on....
SUPERHEAT it ...you won't hurt it....Then force one corner on...& work it to the other end.
Wear some gloves....It is a really tight fit....
joe harper
joe harper
NO...
Put it back in the boiling water.....YOU cant over heat it....I will return to its shape
And conform to the wand....Don't worry..I know it is a lot of money...but you won't hurt it.
daniel@procarpet
Well I got it on. It was like giving birth. No I can't imagine that. :shock: I popped one corner on and then used the rubber mallet to tap it on.
if it doesn't fit, force it
If it breaks, it was meant to be replaced
sweendogg
David Sweeney
:)... who needs a pot of boiling water when I have a heat gun!!! :shock: But, you have to wear leather gloves for that puppy.
