Glide for water extraction. Yes or no?
  • Thread starter daniel@procarpet
  • Start date
daniel@procarpet
I did a water extraction last night on a commercial carpet. I used my hole glide. Man that thing pushes easy. I was suprised how the air just kept flowing and the water was sucked up very easily, but since the wand was not creating a good vacuum seal I feel like I wasn't sucking up as much as I could? Did I do right?
Mike Draper
makes no difference, a wand is not made for subsurface extraction.
daniel@procarpet
Commercial glue down. Does it make a difference?
dealtimeman
Everyday is Saturday.
Michael
for glue down flood sucking it is great just go slower.
Farenheit251
Every carpet is going to be different. I'd definitely start with a hole glide. Truth be told. I usually do a half ass extraction on commercial glue down. With fans it is going to be dry in the morning anyway. Carpet with a pad I'm very thorough.
Jack May
If it's on underlay (yeah ok PAD) then a water claw or other option is a must to start with. Once that is done efficiently and effectively, then a holed GG equipped wand is great to run over the carpet.
If the capret is a direct stick, then a holed GG equipped wand is probably the best choice, you just have to resist the urge to go faster because you can. Slow right down and take it easy without abusing the body and let it do the hard work for you.
John
Just remember ... this ain't rocket science and this ain't ICS.
So, if it seems like it's working ... it probably is.
nope, it sure does make a difference.
a wand is a very good choice on CGD (no pad)
Preferred choice IMO
Mike Draper said:
I was talking about carpet with pad.
ah...gotcha
and i agree
the dude specifically mentioned he was extracting CGD, though
try and keep up, Draper....
:mrgreen: :mrgreen: :mrgreen:
