Blew the fuse on the AT reel motor...where is it?
ronbeatty
Ron Beatty
Mike, there is a breaker in the middle support bar under the hose. It is about 6" in from the back side of the reel. Just push it up with your finger, it will reset.
Yep..
And Jr figured out how to dump a full waste tank with a plugged up drain pipe. The high water shut off float would not let him start the unit to create back pressure on the drain...
That's awesome! He will do fine & having you as tech support has to be comforting.
