Auction Auction - Rotovac 360xl w/ choice of head AND Sheardry upholstery tool
Up for auction:
1 Rotovac 360XL with choice of head.
1 Sheardry upholstery tool (Clear head)
Free Shipping to lower 48.
3200+ Retail Value
Bidding starts at $1500
$20 Minimum bid increments.
Auction ends 8/14/18 at 6PM PST
About the 360XL:
logo-360i-xl-jpg.81357
High Performance Carpet Cleaning Machine
backbreak-jpg.81358
tired-cleaner-2-jpg.81359
Engineered by Cliff Monson, the inventor of Rotary Jet Extraction, the 360XL is designed for high performance carpet cleaning. The 360XL has multiple cleaning head options, a telescoping handle and weighs 68lbs. The Swoop Glide™ vacuum shoes eliminate over-spray while deep cleaning the carpet with unparalleled results.
xl-callouts-diagram-jpg.81360
Rotovac 360XL Product Details
The Rotovac 360XL is a Patented Rotary Extraction Power Head that utilizes rotary vacuum heads to thoroughly deep clean carpet with hundreds of multi-directional cleaning passes. The 360XL weighs only 68 lbs and is extremely easy to use as it operates in a self propelled side to side motion. Simply stated, “The 360XL cleans better with less effort."
Works with most Portable Extractors or Truck Mounts
The Rotovac 360XL is air flow calibrated to work with most portable extractors or any truck mount extractor. Give your business a boost and your back a break by hooking up the 360XL to your existing portable or truck mount.
grant-xl-jpg.81361
    • Features:
    • Cleans better with less effort and leaves carpet drier than a wand
    • Large 15" wide cleaning head
    • High torque motor with tough helical reduction gearing
    • Patented Swoop Glide™ vacuum ports
    • Telescoping handle for compact storage
    • 144 RPM
    • 55 lbs (without cleaning head) 68 with head
    • Rugged cast aluminum frame
    • 2" clear view tube
    • Unique marketing tool, land new accounts and generate referral business
About the Sheardry upholstery tool:
sheardrylogo-gif.81362
sheardry-main_new-jpg.81363
Rotovac ShearDry Video Demo
The Rotovac ShearDry Upholstery Tool cleans in both directions with no overspray or dripping. Constructed of light weight super strong fiberglass reinforced composite, the ShearDry is the most comfortable and effective upholstery tool on the market today.
(Back to top)
sheardry-main2-jpg.81364
    • bullet-gif.81365
      Dual Direction Spray Bar Centered Between Two Vacuum Slots
    • bullet-gif.81365
      Fiberglass Reinforced Composite Body - Strong & Lightweight
    • bullet-gif.81365
      Vac Slots Close to the Front & Side for Better Edge & Corner Cleaning
    • bullet-gif.81365
      Solution Holes Are Only 1/16" Apart for Streak Free Cleaning
    • bullet-gif.81365
      Thin Side Profile for Better Reach
    • bullet-gif.81365
      10' Hide-a-Hose With In-Line Filter
    • bullet-gif.81365
      Super Comfortable Design for Less Hand Fatigue
    • bullet-gif.81365
      Easily Replaceable Cleaning Head - Only $19.95
Up for auction:
1 Sheardry upholtery tool (Clear Head)
3200+ Retail Value
Magic One
Thanks Mikey. I clean mostly residential and some commercial from medium to some heavy soil. What head do you recommend?
Magic One
Mikey as long as don't order from rotovac. Over 6 weeks and no 360xl
Post moved to rv auction thread -anon
Yes your right I should have started a new tread and blasted rotovac Poor customer service
I moved these post to a more appropriate thread.
RV had issues that weren't conveyed to you.
They took too long to get it to you.
I'm sorry for both those things but that doesn't mean you should spam other threads.
RV customer service? Did you contact them?
and btw.......... Although I think it took way too long to get to you it won't be over six weeks even after it arrives at your door on the 25th
