2.5” Hose
joeynbgky
Joey
I did use 25 feet of 2 inch now we use all 2.5 and it seems like the suction is horrible now
steve frasier
I believe Greenie will tell you that anything over 100' doesn't do you any good
I have never run over 100' with the 2.5" filter
Able 1
I'll use up to 50' of 2" in a big house but the sweet spot is 25' 2" whip for my TM. Using it straight to your water claw kicks A$$ though...
Finally upgrade numbers... :D
b]http://www.youtube.com/watch?v=JJMmw2yZWbIb]
daniel@procarpet
Thats a great video. Why not just run two 25' sections of 2 inch and use a "y"?
daniel@procarpet
Oh I guess you will need a dual port machine.
Easy, cut another port and you have a second port to run 4-2 the door.... Or run 2.5 like the video shows and you don't need a second port. :D
Louis
Louis
The guy in the video is the one with the 2k for life time cleaning. Expert Cleaning
ACE said:
How many feet of 2” lead hose do you use?
the overwhelming majority of our hose runs are under 150ft.
we have one 50ft length of 2.5.
i see no need to buy more
any runs under 100ft are 2" all the way.
It's not worth the bulk and hassle for less than 100ft runs.
note, that's on a 45 blower
My guess is: Joey meant to say they used to have 25' of 1.5" Lead hose and now go 2" all the way.....and yes, it would be quieter at the cuff, but recovery is sure to be better even with a 1.5" WAND.
Jack May
On my Legend, modified by yours truely, I run 2 lengths of 2.5 into 1 50' length of 2" and find that it's awesome vac compared to what it was at factory settings.
I recently ran 3 lengths of 2.5 and 2 lengths of 2" and still little discernible difference.
Ther is NO way I'd go back.
John
jhc..would Pink have been a good color as well? That's not even purple, it's lavender, what nut job uses lavender hose?
ACE
Thanks for the replies. I think I am going to use 2 vac hose reels on the Steamway box tuck I’m setting up. One reel with 125’ of 2.5” down to 25’ of 2” whip, the other reel with all 2” hose. I’ll order a greenhorn wand and enjoy the best flow, heat and CFM. It’s won’t be a vortex but I think that the performance will be about as good as it gets for a single wand set up.
Johnny
Johnny
Is convenience the only advantage of 2.5 over 2 X 2?
Yes, from what I've read about it. 2" hose is what I already have. It's going to cost me too much in shipping for 2.5". I make due with what I got. :D
Mike Draper
I use a 25' whip of 2" hose, the rest is 2.5" all the way. BTW, I have 150' of 2.5" hose.
