is there something...
that would make this more secure? This is a replacement hose for a Sapphire Upholstery tool. it broke at this point (weakest link)
something like a hose bend restrictor on a solution line.
A piece of clear aquarium type hose ( too bad you didn't put it on before installing the end) it might be a little tight getting over the ends .or maybe 2 or 3 layers of heat shrink would do it thats what i used on my chem pump lines some hoses i completely cover in plastic hose and seal ends with shrink tubing if for instance abrasion could be a problem but generally speaking when making ⅛" hoses i slip on a piece of plastic hose for support at the ends while making um
Screenshot_20260313_124233_Gallery.jpg 20260313_130428.jpg 20260313_130544.jpg
yes.
I have to say that each fitting was a bear to get off. Dont know why SS tightens fittings so much. Never had that problem with any other tool
Mike's answer above is why I asked.
Most of the time that line breaks is it twists and snaps. Keep those quick connects lubed and your hoses will last.
I think its been about three years since I bought it but never thought to lube the quick connects. The quick connects are also on the Prochem upholstery tool so now that will be part of my regular maintenance.
